Specifically, what gear do you have the pulled tractor in? And what gear do you have the puller in? Yes, I realize this is a approximate question with all the different transmissions out there, but do you use a high gear, low gear, or an intermediate gear?
I typically use second gear on a 4 speed transmission for the puller. About the same for the pullee. Try to have a bit of momentum before pulled tractor driver engages clutch. Even then, I"ve been known to tear up the sod in the barnyard pretty good when load is applied. What say you?
