Is it possible for an injection pump to leak through the front of a tractor only when the tractor is running?
I have an Oliver 1755 that was slowly leaking all the time last winter whether the tractor was running or not. It leaked along the outside of the tube that goes through the middle of the pump; can't remember the name of that tube. I wonder because I have another tractor I don't use much and the oil level seems to go up a little bit over the course of time. I realize there are other possibilities for that, but I wondered if it only leaks when I run it; if that is possible.
Thanks.
Thanks.
