I have a propane water heater that has me worried.
It works correctly, as far as the pilot light goes, heating, turning on and off at the right time.
However, when it cools to the point that the burner has to re-ignite, the gas
valve turns the gas on and then several seconds later it basically explodes to light.
Again, this would seem close to normal, but you can hear this "poof" from 30 feet away.
With the little front cover removed when it lights, it shoots flames for a foot or more.
With all the covers in place, it soots up the front side of the casing outside.
From the access panel up about a foot and a half.
It has been shut down for now, so no big safety warnings, but what would cause this?
This is the second water heater that has exhibited the same behavior installed
in the same place over the past 10 years.
They're fine when new, but then this behavior develops.
