Fergienewbee
I'm in the process of expanding my kennels. I have a piece of fence 139" by 6' heavy gauge wire. I want to make a panel 144" + or - including 1-5/8" end posts. How much stretch can I get? I figure the fittings will add around 3" to the top and bottom rail. The other option is to use a part called an end post clamp. The clamp bolts to the end post and makes a tunnel that the top rail slips into. That way I could put one end together solid, add the fabric, tension bands and clips, and stretch the other end and screw it together. I'd appreciate any advice.
Larry
Larry
