Anonymous-0
Didnt have much time to work with it, but I did swap the hose to each port and it still will not hold pressure up. It will hold all the way up if you hold the control rod for say 3 or 4 seconds after the cylinder reaches its full extended position, but anywhere else, it just drops back down. I dont think its a problem with the stub on the rod, my supervisor says its got to be something in the pump, sinc it does the same thing even with the rod disconnected. Ruling out trash, as was suggested before, what else could cause this problem? All we did was do a direct swap from one tractor to the other, and it was working fine like an hour before. Ill try to check in later today, but again, thanks in advance.
