pto slipping on a jd 2955
m ford
New User
I have heard that you can shim the valve for your pto if adjusting the shift linkage doesnt help. Has anyone ever heard of this? if so how is it done? Thanks.
You could add some shims(parts key #23) but if sealing rings on pto clutch were very bad I still think the pto clutch wouldn't hold under extreme loads. Do you know what the pressure is now??
not sure but i will check. Whats happening is my pto slips periodically under a heavy load. the sump filter is clean, good fluid,clutch pack is good.
