CarolynDiesel8N
New User
the pump on my 8N malfunctioned. I got that fixed but discovered that the shaft that is supposed to power it does not. The shaft currently moves at a slower rotational speed than the engine. I was told that the shaft was made to strip if the pump seized in order to protect the engine.
I am trying to remove the shaft from the hydrauic hub but I have not been successful so far. I removed the nuts connecting the hyrdraulic hub. I have dropped the pump so the shaft can pull out. But I have not been able get the shaft out. Sometimes the shaft turns/spins freely if it is pulled out a little bit from the hub and other times it won"t budge.
It was suggested that I have to get what is left of the spline lined up so that it can pull out of the hub, but I have been trying slight rotations to see if I can get it lined up but it has not worked.
What is the trick to removing the shaft under this situation.
Thank you very much. I really need my front end loader.
Carolyn Diesel 8N
Carolyn Diesel 8N
