I need some help. After going through the manual and everything checking out I finally decided the engine should crank and run but it would not, so I advanced the distributor for around 10 degrees to 25 degrees and the engine starts right up every time. Reinstall the little plug next to the fire wall you have to remove to set the timing and it cranks and starts just fine.
Problem is the timing is to far advanced to keep the engine cool and to have any power.
What has messed up or went out to cause this change in timing? At 82,000 miles I don't think the timing chain has slipped any and I know the distributor has not moved.
What electronic part do I need to replace to fix this?
Thank you for your help.
