Anonymous-0
Don't beat me up here.. This just crossed my mind and wondering if it will work or why it would be a bad idea.....
Have a couple of seals leaking (seeping) a little on the hydraulics (lift arms and the control lever shaft).
Remember the "fix" for slight main seal leaks was adding a quart of ATF to the motor oil.
Would ATF hurt the hydraulic system on an old tractor? Would adding a couple quarts to a 20 qt system be enough to swell the seals a little to stop the leaks?
Just a thought, but don't want to do any damage. ATF is hydraulic fluid also isn't it?
Thanks, Dave
Thanks, Dave
