There will be opinions and preferences by many I am sure.
Its nice to have adequate light when placing concrete, for the finisher at least, building that size, access for the chute, or for some reason you have a pump, probably not necessary, but its wise to consider how the material will be placed. So roof on or enclosed or not, kind of optional, enough work lights can be set up to illuminate or permanent lights installed before hand. Definitely need light one way or the other.
I'm not familiar with the slab edge and column detail is with pole buildings, maybe there is expansion joint or isolation joint around same for preventing cracking, but would assume the columns and the roof framing, and tin would be up, that would prevent weather effecting the finish, like a sudden rain or what have you. Access through the sides, whatever nailer or blocking for the tin is needed, bracing might be in the way, you could plan areas for the chute to place if the doorways do not provide enough access already.
If placed early, you'll want to wait the 28 days for curing and compressive strength, but afterwards, for remaining work, nice clean surface to work off of, just not something I would do if that is the finished floor surface and theres a bunch of trades that will work off it to complete the building, pole building likely not the case.
Don't forget reinforcing, extra where needed, all the stub ups, conduit, pipe, pex for heated floor and or anything extra like spare conduit, pipe for future use etc. Euclid Chemical Company makes great finishing products for your slab.
