HP req. for feed grinder
What are you grinding? How fine of screen?
80-100 hp would be a reasonable start. Is it a 540 PTO unit?
The manual for my 354 just says minimum 3 plow tractor. I can run it OK with my 53 horse Oliver 1550,but I usually use the 90 horse 1850 diesel. The guy who had it before me always used a 56 horse 1600 with no trouble at all.
If you are short of time and have an unlimited budget I would start with 100 hp and go up from there. If you are like me and have more time than money a 50 hp tractor will run it but it'll make her bark and I don't stop the pto until the grain tank is half empty.
I agree. My Oliver 88 (39 HP)will run the grinder, but if you crowd her too much it sure makes her jump. The Case 1030 (90+ HP) does it a lot better and quicker.
I have ground feed with my 55hp 170 Allis Chalmers, but any of my 70-95hp tractors do it better and faster.
We ran the mixer grinder with an M Farmall. It was kind of nice cause you threw in a couple shovels-full and then waited. I remember it really working hard when the cakes of alfalfa went in. When we finally switched to the IH 966 the slow pace was over.
For years, we have used AC D-17s to grind ear corn as fast as we can rake it into the hopper. We use a coarse screen for that (~1" holes, maybe?) and it really eats it up. When we grind a little bit of chicken feed (2 corn/1 oats) on a fine screen, though, the oats really slow things down. It doesn't have much trouble with shell corn alone. D-17s should be in the mid-50s on horsepower.
You can get by with 60 horse and do a reasonable amount of grinding. If you want to push oats through a 5/16" screen at a good rate you better have 100 horse in front and that will get worked...
Rod
