786 International tractor loader question
I have a 786 International tractor and need a loader but not sure what kind will fit it. I would like to search for a used one. Does anyone know what type, brand, size, etc. would fit this tractor so I can try and search locally?
Thanks!
Most of your modern loaders are "universal",only the mounts are changed,most of those can be modifyed to fit your tractor.There many brands out there,most are of equal quality.Go talk to some of your local implement dealers(it doesnt have to be a CaseIH dealer,either),put wanted ads in local papers,Craigs list,etc.Look on the "Tractor House" site.
Don't know what area of the country you are, but here in the dakotas, the Du-al 3100 and 3000 was used on a lot of 86 series Internationals. This loader was used on a lot of tractors in the 80 - 150hp range. Loader is all the same, only the mounts change. I have never seen a 786, not sure if it uses the same frame and chassis as the larger 66 and 86 series. Here is a picture of the 3000 loader. (same as a3100 but different cylnders) Its a good loader, easy to take on and off with no jacks.
I have a Westendorf WL-27 that I switch between my 686 and my 886 IH tractors. Friend has an International 2250 mount-o-matic on his 656.
