Inner Fender Tool Box
forddaved
New User
I just bought a fender for a 2N Ford that has a tool box cut out. I thought my tool box would fit over it and it doesn't. Does anyone know where I could find a tool box that would fit on the outside of the fender closer to the tire. You axis it from the inside closer to the 3 point side through the opening on the fender.
Ferguson and MF used exterior fender tool boxes but not Ford/Ferguson.
Reproduction MF toolboxes for use with your Ferguson/MF fender are once again being made and likely available on this site.
Dean
Dean. Maybe my fault but the guy I bought these from said they would fit on a 2 8 or 9N/ Would these not fit on that if they are off a MF? I thought I saw a photo of an 8N with this type of tool box fender.
The fenders for the Ford 9N, 2N, 8N, NAA and the Ferguson TE & TO 20 and TO30 and TO35 all will bolt interchangeably and someone that is not up on things might just not know what model they were made for, just what they might have come off of that someone previous put the wrong model fenders on.
Like Leroy says, the fenders will interchange but only Ferguson and MF used the exterior fender toolbox as OEM equipment.
Dean
Leroy, Thanks for the information. I have another question. Do the MF fenders look exactly the same including size. Are there any differences from the ford fenders other than the cut outs?
That I cannot tell you. Just know on all of those tractors the under fender mount brackets are the same for all of them and mount on the same 2 bolts so the fenders have to have the same mounting holes. And they are all the same size wheel so fender size would be roughly the same to fit the wheel.
