SweetFeet
Need to remove the shaft from front axel of a Farmall F20 (going to put the axel on our Regular as it has bad threads).
1. Is it a straight key or a halfmoon key that holds the axel straight on the shaft?
2. Husband has tried heating with torch and pressing out with a 20 ton hydrualic jack...not working.
3. Anybody with experience in doing this have a better method? Or does he just need to buy a 30 ton jack to put in his press-frame?
Thanks so much if you can help!
