How old are the R22 out of the box units?
Probably brand new. Since 2010 the manufactures have not been able to ship units charged with R22 but they can ship what they refer to as “Dry units” these units have no refrigerant ship with the unit but normally have a positive charge of nitrogen gas to keep moist air from entering the unit.
Wasn't R22 ban Jan of 2010?
Not true R22 is in a phase down cycle see the following source
http://www.epa.gov/ozone/title6/phaseout/classtwo.html
Isn't the price of R22 about $400/30 pounds
I remember when it was $25/30 pounds
I haven’t bought any for a while but that sounds about right.
I remember buying it for 0.60 cents per pound.
How much longer do you think you will be able to buy R22?
I think for quite a while, there are replacements being produced for R22 but right now they cost as much as R22 so there is little to be gained by using them.
The replacements have similar pressure temperature and enthalpy to R22
If R22 was ban, is it likely what you are buying is used recycled R22?
One again not true please refer to the EPA site.
Isn't the efficiency of 410A better than R22?
Not at higher Ambient temperatures
Don't the 410A work better at a lower temps?
Not sure what your point here is but R410a is normally used as a medium temperature refrigerant intended to be used in things like air conditioners.
What's the warranty on your old R22?
No warrantee on the refrigerants only the equipment. Since I am out of the business can not address the new warrantees but you can Google some of the big manufactures and check the warrantees on the “Dry Units”.
What's the warranty on the new 410A?
Are you telling your customers all the facts about R22 or are they just looking at cost
I am not sure who you are addressing here but I sure cant answer that one.
George"
R410a is not a magical cure refrigerant, the lubricating oil that is used in the 410a sealed units is very hydroscopic, some tests have even proven that POE oil stored in a plastic container will absorb some moisture in a new sealed bottle. Moisture in a system will react with the oil and will deteriorate the motor windings and in some cases cause sludge formations that can plug up a system.
Carless installation practices that might not matter in an R22 system can spell sudden death for an R410a system, special care must be taken, things like purging nitrogen while brazing, pulling a deep vacuum verified by a micron gauge and the use of filter dryers.
Actually not only does R410a require higher operating pressures which can result in stress on the components but if you study the performance curves of the refrigerants at higher ambient temperatures R410a’s performance actually drops off.
Having said all that if I need a new unit it would be 410a but you can be sure I would make sure the installation was up to snuff because asfar as I am concerned, that is more important than what brand you use
