2-62 4x4 hub
Jeff Jerger
New User
Anybody out there have a hub for a 2-62 4x4 or the whole front axle. or some one that has a parts tractor sitting in the bushes? my dad bought this tractor a month ago its in good shape and never would have guessed the wheel would just fall off. checked every salvage and used parts destribtors even iseki farm tractors in hawaii. nothing. realy hope someone can help. please email me if you have any info. THanks
It might Help IF your told us what brand!!!! I am guessing that it is an White/oliver/MM. Then tell us why the wheel fell off and what broke. We may be able to help you fix what you have.
So give us a little more to work with and maybe we can be more help.
If it is a White 2-62 then it is the same as a Iseki T6500. White only sold them one year. So I would bet that used parts are just about impossible to find.
jd seller. thanks for the reply. it is a white 2-62 4x4. the hub on these are held in with a snap ring and the planetary assembly as a unit and when you bolt the the outside hub housing on it holds everything in.The hub broke in between the planetary gears and left the rest of the hub in the casing. took it apart last nite i dont think it can be fixed because it broke where the splines are that meets the ring gear. dad took it to a local shop that can fix anything that can be fixed but im not getting to excited. found a t6500 in australia thats a salvage and the axle is complete. but probly big bucks to get it. but the tractor is worthless without 4 wheels on it! im lucky i wasnt driving down the road when the wheel fell off! witch i had been 20 min before it did. could have been real bad. let me no if you hav any ideas. Thanks!
How about another one for parts? I just saw one in the Michigan Farm Trader with a broken front axle. Has a loader,$4000.
Must be they cant find a hub either. thats not good. Ours has a loader and a cab with a heater and radio. cannot believe iseki dosnt have any of these things in japan they sold a bunch of them over there and they new they had problems. is there any other models they used this front end on? they made these white models 2-62 2-65 and so on into the late 80s i think?
