jd4204204010
New User
1963 deere 4010 with dual rear remotes... LH remote set was working fine with haybine for a few days on the 4010, but now after the haybine is down and control lever returns to the detent or neutral position, the haybine slowly raises back up on its own!... I switched the haybine over to the RH remote set and it works just fine over there... Is problem inside the LH remote actuating valve body? I suspect it"s leaking by internally for some reason.
Only thing unusual is I"m running a single-line remote cylinder for the first time on this 4010 and deere dealer assured me it would be okay to do so without a return line .. .this haybine has been single-line with no problem on other tractors, red and green...
