I am in the research phase of a project that will incorporate a hydraulic motor. I have one here that runs a few hundred rpm. I want to use it to run a table back and forth (about 20’) It needs to be variable speed. Generally feeding will be slow, return fairly quick, but I may want to run it faster or slower as needed. The plan is to have a chain that is threaded through a hyd motor with the ends fasten to the table.
I am looking for a control valve that is kind of like an outboard boat motor control. When the handle is centered, the motor has no movement. Push one way spins the motor in on direction. Pull back it spins in the opposite direction. Both forward and back is like a throttle, the further you go the faster the motor spins.
I know they make such a thing because I have two in my skid steer. As the lever is pulled back the motor (wheels) begin to turn slowly. Pull it all the way back and it is spinning. I am not to concerned about load control as this will be operated manually and I can adjust for loading.
What the heck is that control called?
I have search;
Hydraulic speed control
Hydraulic motor control
Hydraulic flow control
I have search;
