ford 4000 fuel injector 3cyc.
Anonymous-0
I have a ford 4000 I was bushhogging at the of the cut the tractor was loosing power like it running on one cyc. like it was starving for gas I took loose the lines going to the injectors loose turned the motor over several times but could get no fuel to pump what could be the problem? where is the metering valve
Easy/cheap things first... Do you have good flow from the tank? (there's a screen on the intake - unthread the shut-off valve from the tank to check and clean) How long since you've changed the fuel filter? I'd bet one or the other is plugged.
