Swimming Pool O.T.
DownSouth
Living just a few miles from the Mexico border, I thought you folks might get a chuckle out of this:
Poor Mexican's Swimming Pool
Rich Mexican's Swimming Pool
4'x8'x1' bed =32cu.ft.x 8lbs/cu.ft. =256lbs and if you went 2' deep (which it isn't) then 256x2=512lbs. A lot less than you were thinking it did.
oops...that's 7.5 lbs/gallon and about 8 gallons/cubic foot. So...about 62lbs/cubic footX 32 cubic feet =1984 lbs or a ton....that's a big oops. I hate screwing up.
D3B, I thought it looked new or near new too but if you see where the water appears to be weeping through the center I would say it has a big gash.......nothing a boot wouldn't fix though!
I'll bet they just cut a piece of metal a little bigger diameter than the diameter of the bead, then gooped it up good with silicone and bolted it on. Pour a couple sacks of Sacrete over it to level it up, and you're done.
I made a base for a tetherball pole once, with an auto tire and the top of a barrel- stood a length of pipe the proper size in the middle, poured it full of concrete. Kids played with it a couple times, then lost interest in tetherball, and I finally buried it.
And the pipe coming out of the wall comes from where???
I hate to say that my first thought was a drain of some sort. . .
Surely an air conditioner and not a urinal.
Darn, I wish I hadn't posted that. It was in poor taste, and I apologize if I offended anyone.
Paul
You may be right, but it looks to me that there's at least a six-inch ring of sidewall missing.
Surprising the things you "forget" as time goes by. We did that with my truck several times one summer when the kids were small. Sure was easy to empty when you were done!
(quoted from post at 16:22:43 06/10/12) Darn, I wish I hadn't posted that. It was in poor taste, and I apologize if I offended anyone.
Paul
idn't offend me! Went swimming in muddy tanks many a time. Just goes to show ya that you don't have to be rich to have a pool & where there is a will there is a way!
You caught me! Perfect example of overlooking the obvious- I was thinking of how they waterproofed the bottom, did't even look at the top.
I thought water was 8lbs to the gallon. I always learned water was a pint a pound. 8 pints in a gallon thus the 8lbs per gallon.
