DAVID BROWN 990A REAR END
L.j. MARTIN
New User
I JUST COMPLETED REPAIRS TO THE DIFFERENTIAL ON MY 990A WITH 12 SPEED TRANSMISSION AND NOTED THAT THE MAIN DIFFERENTIAL CARRIER CASTING HAS SLIGHT MOVEMENT IN THE REAR AXLE HOUSING AS IF THERE ARE BOLTS LOOSE SOMEWHERE. BECAUSE THAT CASTING HANGS OFF THE REAR OF THE TRANSMISSION I'M SUSPICIOUS OF THE SPACER BARS BEING LOOSE IN THE TRANSMISSION. CAN SOMEONE GIVE ME SOME DIRECTION. I'M IN OREGON AND THERE ARE FEW DAVID BROWNS HERE AND NO KNOWLEDGEABLE PEOPLE TO CONSULT WITH. THANKS FOR YOUR HELP.
You might want to post this on the Case board. There are some people that monitor that board that are familar with the David Browns. Lee
