Coyote Green
I just put a Gear Hydraulic Pump on the front of our garden tractor, after building mounts and finally getting the pump mounted and plumed i found out that the pump is turning the wrong way. Can i just switch the "in" and the "out" and run the pump "backwards" ? Will this damage the pump or does it matter?
I would rather not rebuild all of the mounts because i barely got the pump in there as it is.
Any impute would be great
Thanks
Thanks
