Ford 172 diesel adjustment point
Pls what is the firing order for a 172 ci 4-cylinder diesel engine? The injection pump is a Roosa Master DBGVCC 429 8AJ and code of the engine block is D2NL 6015 A? How can you identify the first cylinder and how to get some pictures on installing the fuel pipe? Is there any instruction on how to set ignition timing? I'm in Brazil and the tractor was out of the pump and I'm reinstalling it.Tks!
This is a Ford tractor, right? Probably a '62-'64 4000? The cylinder closest to the radiator is the #1 cylinder. Firing order is 1-2-4-3, I think. If you post your question on the Ford forum, you'll be more likely to get the answers you need.
