Zachary Hoyt
I have a couple of small sheds in which I keep hay, most of which gets sold over the fall and winter. They are dirt floored with a metal roof and wood sides, both fairly new. I get wood pallets and put them on the floor to stack the hay on, my problem is that I have been having some trouble with the bottom side of the bottom bale developing mold. The rest of the hay is all fine. One person told me I should lay down plastic under the pallets to keep the moisture from the ground from getting into the hay. Is this a good idea or is there something else I should do? There is no drainage issue, both sheds floors are high enough that water does not run into them when it rains. Any advice will be much appreciated.
Zach
Zach
