Question for jm or anyone about a Kubota??
Tx Jim
The pto seal is leaking so I installed a new seal from Kubota. It still leaks but between shaft and steel insert(resembles seal saver) in seal. What do I put between shaft & steel insert to seal it?? Thanks,Jim
Jim I think the shop uses a product from LocTite. Any good sealant, not any preasure there but just the oil seeping past. Getting it dry and clean will be the secret. Sorry I can,t be of more help but Your parts store should know of the locktite sealant.
(reply to post at 08:13:59 05/27/12)
jm
Thanks for quick reply. The Kubota WSM(tech manual) didn't state any type sealant required but with oil leaking between shaft and metal ring I thought some sealant was necessary.
Thanks again,Jim
jm is correct. The Loctite product made for retaining/sealing cylindrical products. It is rated to fill gaps up to .005. It is oil/grease resistant. I use it all of the time for bearings, seal wear sleaves, and drive shaft yokes.
The number and name: Loctite 603 Retaining Compound
I had to go look at my bottle to see the product number. I first got to using this twenty years ago. JD had a PIP that called for it. I had to order it from the local Loctite dist. He told me what all it was used for. I have kept a bottle ever since. I have not ever had an issue with a speedy sleave leaking when I use this. I also use it on PTO bearing that are supposed to seal the oil too. I have had them leak between the shaft and bearing too.
I use the ten ounce bottle and it is about Fifty dollars. I am sure they have it in the smaller tubes too.
Hope this helps.
