Case 430G Hydralic Trouble
Anonymous-0
I drained the fluid from loader and cleaned metal filter. I filled loader and things worked fine for a while. When loader and 3 point did not work I added fluid. I overfilled the loader and fluid blew out under seat from a vent and 3 point leaks down. Now the loader or 3 point won't work aqnd I am sure its low on fluid. I don't have a book. Should fluid for 3 point be added somewhere other than loader fill? There is a plug on top by gear shift. Should fluid be added there? Or does hyralic pump need work where ever it is located.
Sounds like you have a leaky 3pt. piston seal.
Repost on the CASE DB Forum, and we will walk you through the repairs necessary. We will need a bit more info. SN# will be helpful, and a pic. of it so we know what you have for a loader, and how it is plumbed.
Loren
