Wheat Farmer
Just had the injector pump worked on and the steel lines at the pump are leaking again. Would it work by putting a copper washer on each side? Would it be smart to fix one then start it before fixing the next one? Any other ideas?
Had something similar happen and replaced all the copper washers and torqued to spec. And it still leaked. Closer examination located a crack between the banjo fitting and the steeling tubing. Silver soldered it and has held fine for four years so far.
