Delcotron 12SI 1/2 wide pulley
Duner Wi
I need to find an A belt pulley (1/2 inch) pulley for 12 SI. ID is about .670 inch. OD need to be about normal size on Delcotron. Thanks.
Visit your local starter/alternator rebuild shop. They will have a large selection of used sheaves including "A" width you need. Tip: Get the smallest OD you can find. Slow-turning tractor engines need a small sheave on the alternator to spin them at the RPM's they need.
Alternatively a sheave from most any old Delco tractor generator will fit. I used one salvaged off a '47 Minnie-Mo U - it fit the Delco 12SI perfectly.
