50 gallon 3 point sprayer
MSS3020
I have sprayed with a "tsc" 50 gallon 3 point sprayer for a few years now. Basically Amine 400 over hay ground. The nozzles that came with put out a mist which has worked well BUT..I wouldnt mind being able to spray a little faster.. WHat spray tips to you all use??
I bought one last year at TSC. I use it for spraying Roundup (generic equiv), Prowl and Bicep. I'm amazed at how well it works as compared to my old big sprayer with the PTO powered roller-pump.
I never though such a cheap simple device could work so well. C
(quoted from post at 10:59:20 05/01/12) I have sprayed with a "tsc" 50 gallon 3 point sprayer for a few years now. Basically Amine 400 over hay ground. The nozzles that came with put out a mist which has worked well BUT..I wouldnt mind being able to spray a little faster.. WHat spray tips to you all use??
You need to figure out how fast you want to travel and how much carrier and AI you want to put down per acre... from there you can select a jet... sprayer calibration is important.
Kills the weeds.. will also put a hurt on alf and clover HOWEVER.. if you to kill alf better to spray in fall right before winter..
