showcrop
Working on getting the hay equipment ready. The old 640 JD rake had given me cause to inspect the gear box and sure enough it had a bad bearing. At another point there was a grease fitting that didn't want to take grease last year. I removed it, sprayed penetrating oil in, worked it a few times, more oil, then a new fitting. It took a little grease, so I worked it and greased it, and ended up getting the joint greased. Pulled out a wagon that needed deck work. I was greasing the front end and the main pivot wouldn't take grease. I had to fight with it some to get the old one out but I finally beat it using the same process. It felt good to beat to stubborn grease fittings in the same weekend.
