Part one is the bar on the Mf65 is lower than I'd like, and the gate it's meant to swing in has been repaired with 1/2" vertical clearance. I'd like to weld in maybe a 3" wide flat bar underneath it to get that height. Any reason mild steel won't do that job well?
Second part is putting a bar from the straight, upper, front section of the drawbar, to straight out above the drop section. Thinking welding it around the forward section with a wrap around the vertical area of the drop so as to not weld or drill to/on the drawbar itself. I assume that drawbar is heat treated, right?
What do you guys think?
