keep birds out of the shed
anyone know a way to keep birds out of a 3 sided open faced shed.most likely impossible i would say there droppings are making a mess on my three tractors and all of my equipment.only way to stop it that i can think of is put up some kind of screen or chicken wire stapled to the underside of the trusses but that would be a job in itself.anyone got any ideas.thanks
RICK
Get some VHS or cassette tapes and take em apart and hang streamers. Gonna be hard to get rid of since theyre established.
Hang a owl statue in there it"s a natural predator if you hang it from a rope the wind will move it make most birds think its real and flying around
I have a customer that tried all kinds of electronics, plastic owls bright balloons etc. They finally stapled chicken wire to the underside of the trusses.
Several years ago we were having trouble with birds in the hangars at the airport. One plane owner in ur club said he fixed the roblem in his hangar. Ged them ground corn, soaked in anti-freeze. Said finally the birds quit coming to his hangar.
I got a fake perched owl that I keep clean and move around the shed but the sparrows still keep coming around. I never tried hanging it.
Go down to the sporting goods store or a good fishing joint and get a large spool of fishing line, monofiliament, about 4-6 pound test. Then get a ladder out, and string it from one end of your shed to the opposite end in random fashion as many times as you can, above any machinery height, and as low below the roof line as you can whereever you can. They can't see it in flight and after a few collisions, they decide there is safer airspace somewhere else.
I have a 48x96 shop, half being open front machine storage. I had three of the balloons in the open part- worked fine til one was lost. Then I hung CD/DVR discs from the rafters, junkers, freebies, etc. If they are on string, they move with just a bit of wind...reflection scaring the birds away. On wires, they don"t move enough. Some put nails along the lower chord, clip off the head. Grease would be worth trying as well, plus the anti-freeze thing.
(quoted from post at 21:01:19 04/28/12) I have a 48x96 shop, half being open front machine storage. I had three of the balloons in the open part- worked fine til one was lost. Then I hung CD/DVR discs from the rafters, junkers, freebies, etc. If they are on string, they move with just a bit of wind...reflection scaring the birds away. On wires, they don"t move enough. Some put nails along the lower chord, clip off the head. Grease would be worth trying as well, plus the anti-freeze thing.
The CD's work pretty well. Also do a decent job with garden pests (think better if they have light to reflect). You'll see places here with thick hog and deer populations where the discs are hung along the sides of the roads which really reduces roadkill.... Stringing fishing line around the rafters also helps (does here for pidgeons anyway).
If you have owls or little falcon/hawks (Kestrels?) in your area, set up a nest area for them and you can help yourself and nature at the same time (this idea won't be real popular with the coke & flybait clowns)...
Good luck.
The rubber snakes work, and even a short length of an old grass rope. I put a short length of rope on the edge on my water tanks and that keeps them off. I have even used a black and yellow rope.
My bird problem went away after I got a few wild cats living in the buildings. I don't feed them alot either. I haven't seen any signs of mice either since they moved in.
