starter commutator
montidale
What is the best way to clean a starter commutator without turning it on a lathe.Seems to me there was a special sand paper to use that wouldn't plug up and short out between the commutator. Dale
Nothing special just use the white or red color paper not the black as it will short it out. It's best if you can the get strips and pull from the ends like polishing your shoes.
Walt
I've used emery cloth or wet and dry 200-300 sandpaper. Most commutators have an insulation between segments. However if yours doesn't use a tooth pick and scrape out the copper between the segments. If you have deep pits, you may have to use something rougher and then polish with finer.
I like wet and dry sandpaper, because it doesn't leave particles of sand behind.
We always had a special roll of commutator paper for years. All of a sudden, our supplier says, no more. Just use regular emery cloth , no problem. We were always told it would imbed in the commutator but I see no problem. If you don't have a commutator lathe to clean them up you can make a v-box and use a file. Starters turn slow so a little run out is no problem. You just have to take your time and they turn out surprisingly well. On a generator it is a different situation altogether.
The pro's use a fibre-glass rod, however unless the commutator is badly scored or pitted it shouldn't be necessary to use abrasive. Ideally, if the scoring is not great and the surface is just dirty, use only a solvent to clean down and inspect. The working surface area ideally should be a 'chocolate brown' colour (once you get rid of the carbon), identifiably darker than the 'unbrushed' areas. If this is the case, the copper has been surface hardened, polished and is in best possible state. Removing this with abrasive takes it back to soft copper and increases wear. Clean between the segments with a toothpick or matchstick, clean off again with solvent. Light scoring is no problem, new brushes will bed in over it. Make sure the brushes / holders dont bind and spring pressure is good. If the commie is grooved or heavily scored it may need skimming. If the brushes are worn short enough to reduce spring pressure, then replace them. To bed-in new brushes, wrap a strip of emery - rough side up - around the commie, allow the brushes to press against it and rock the commie to shape the brush.
