Josh in Pa
I am working on an gas powered air compressor, maybe 120 cfm or so. The engine is not running yet, but will be soon. I know that the oil cooler leaks, I think it is steel and looks rusted at the bottom of the tubes. When craning the engine with the battery you can hear air leaking out of the oil cooler. Can this be repaired, and if so by who? Is the oil cooler on a compressor under the full operating pressure (125 psi) or is the pressure in the cooling circuit reduced? Can I find an oil cooler off some machine in the junkyard that will work, or do I need one made for a compressor? It looks expensive, I'm betting more than the compressor is worth. Thanks,
Josh
Josh
