NEUFIELD backhoe loader info
BLW
hey guys and gals I have a neufield backhoe loader and need info on the batterys 6 or 12 volt it takes 2 and are they hooked up paralle or tandem also info on the fuel pump size and where it can be purchased and any other info i can get also need a 16.9 X 30 tube for the rear tire it has a leak and before i get the tire people to take it off i would like a tube even a used one in good cond just in case the one in it can"t be patched thanks a lot blw
Originally had 6 six volt batteries in series for 12 volt operation. I just use one large 12volt these days, 1000cca and away you go.
For the fuel pump, depends on whether you have a diesel or gas model, are you talking injection pump on a diesel or lift pump...
Any idea what model it is... should be a brass plate just rearward of the rad on the right side chassis rail... The tractors didn"t change much over the years... biggest change was from 5 speed tranny to 10 speed in the 60"s, then syncro in the late 70"s.
http://www.thenuffieldandleylandtractorclub.co.uk/wp/category/home page/
it is a diesel mod 460 the pump is a lift pump from the tank to the injector pump thanks for the info any more would be greatly appreciated thanks again their is no name or model # on the little pump it is an inline pump
