problem with automatic markers on a case 900 planter
Larry Custer
New User
My husband is having problems with the automatic markers on his Case #900 corn planter. He cannot advance markers from switch in cab. They will not
work from the cab. Has new control module, new selector switch and pressure switch and still does not work. Anyone have any suggestions. Thank you
I fixed our markers when they quit a couple years ago on the planter. Running a new hot wire to a double throw center off toggle switch and ran the switche outputs from that toggle switch to the 2 marker solenoids on the planter. Then I could manually choose witch marker went down.
He needs to check the wiring harness out. I am willing to bet that a wire is broken. I have not worked on a CIH 900 but have worked on IH 800 some.
