37chief
- Location
- California
I have wanted to check the draw bar pin on one of my discing tractors for a long time. Today I tackeled it. I pulled the pin out, and most of the wear was on the draw bar hole, so I found a good used one, turned the pin, and put it back in. Good for another 40 years. I will never see that pin again. I also changed the water pump on my old chevy flat bed I use to haul the tractor. It should also last my life time. I was going to change the trans fluid in my MF, but that will be another job for tomorrow. Any one of you do anything today you kept putting off? Stan
