John Deere 45 Combine Square back Auger help please.
Anonymous-0
I need the parts list blowup of the unloading auger on a square back 45 combine. The auger in the bottom of the tank is not turning and I cannot figure out what holds the shaft in the auger on the right side. Not much fun unloading with a 5 gallon bucket. Thanks, Ricky
Ricky, if it's like the 105 it either has a goofy cast coupler that is supposed to act like a flexible coupler between the drive shaft and floor auger flighting, or it simply has a bolt through the drive shaft where goes inside the auger flighting. There was a serial number break in there that determined which one it has. Don't know if that's the way with a 45. My guess is the drive bolt broke but unfortunately it's just inside the tank and the tank needs to be cleaned completely out. For my 105 I made a crank like a tractor starting crank so I could turn the floor auger from the left side with the unloading auger folded back, to empty the tank. Maybe that's why I had to have shoulder surgery LOL!! Jim
