UTV pull type flotation sprayer
df
I need a high flotation pull type sprayer with a 50-100 gallon tank to pull behind a Kubota RTV 900. I need it to be able to put our about 30 gallons per ac. to spray Liquid N on small grain and pastures. Any ideas?
thanks
DF Where are you located.. would like to see the rig when you get going.. Did you get the duals worked out ? jm.
If you are going to try to pull it through any mud, that is very hard to do. I had a 110 gallon tank on a frame with wide tires and it was very hard to pull and couldn't do much if there was any mud. I would try to mount the tank in your bed if you can. 30G/A is alot so you will need a big pump or go very slow. Get a TeeJet book and use their nozzle charts to find what you need.
