OT: No more landscaping timbers in my future
Geo-TH,In
No more AC2 treated landscaping timbers in my future. They make good termite food. Timbers are 4 years old.
Replaced flower box with cement. If the termites eat this, I give up.
There's a .40 treated and a .60 treated. The .40 are junk. Found that out when a guy just to the south had a new pole barn built and the poles rotted off in a hurry. They said those .40 were nothing but landscape timbers.
20 years ago you could buy green and brown treated landscaping timbers. I still have some 20 year old brown treated and they still look good.
Frightning to think they use the same lumber in a pole barn.
My Father in Law worked in a saw mill with a treatment plant for tweenty years. He informed me that "landscape timbers" are not dried before treating. The are put in the treatment vat as soon as they are cut. All other "treated" lumber is dried to a certain percent moisture before being treated. I have used booth .4 treated landscape timbers and .4 treated 4X4s on the same flower bed and the 4X4s lasted two to three times longer.
You may find it hard to believe, I've seen termites eating the inside of a RR tie. My termite guy says that if wood is in contact with the ground long enough, termites will eat it.
Built a big dog pen, used lanscape timbers as fence posts. Been sitting on shale with two feet of clay on top for close to ten years now. Solid as the day I put them in.
"landscape timbers" are a product of a price-driven market. Way back when they were a new category of"treated" for price-only buyers. One gets what one pays for. Had you purchased "treated to refusal" quality, it would have cost you more initially but not as much as redoing it now.
You just believed the name, "landscape timbers" and thought that was just the ticket, which is understandable.
There is nothing wrong with GOOD, PROPERLY-done treated, it's just that landscape timbers are an inferior product.
I heard not to buy landscape timbers as they are made from what is left from a plywood veneer log, and the center part of the log is not near as good as the rest of the log. Also with buying 4x4 treated, do not buy 8' as they also are from the log centers. Buy 10' 4x4 and they will be a better post.
As said by others, not all treated lumber is the same. If it is to be in contact with the ground you need ground contact rated boards. For above ground you can use the cheaper stuff. Tags on the end of the boards will tell you what you have.
If you locast post they will last forever. I have some on the farm that are over 100 years old and are still solid for fence post.
It's always been pot luck with treated wood. They are suppose to put the timbers into a tank under pressure which forces the chemicals all the way through the wood. The problem is there are many unscrupulous companies that will put the timbers into a open tank with the purpose of just staining it green. Then since the concept of treated wood was such a great idea people started using it for raised beds in their vegetable gardens. The early treated wood contained arsenic and people were poising themselves by the stuff leaching into the soil. Then big brother got into it and made them quit using arsenic. Now the treated wood rated for ground contact is fairly good if done correctly but it pales to the day when it had arsenic.
I don't mean to be offensive sir but I was stumped by your answer until I realized that you were referring to posts made from the Locust tree.
Mark
Yep. The wife wanted a raised bed to put some stawberries in. Told me she didn't want to spend alot of money. She has one now, it's 18.4" tall, and 38" wide circle. If any critters eat it, they are welcome to it, I ain't stop'n them.
Dave
(quoted from post at 05:23:51 03/26/12) If you locast post they will last forever. I have some on the farm that are over 100 years old and are still solid for fence post.
If you're referring to locust, it depends on where you live.
Here in the hot humid Deep South, there's no wood that will last underground unless it's thoroughly treated. Even wood laying on top of the ground will soon succumb to rot or termites.
