You need to give us a little more info on what parts you need. There are different places for parts to be found after market. A&I is not bad for brake and clutch disks. I have gotten hitch parts from Abilene Machine.
Just be ready to lay out the money if you have to go to AGCO. I was working on a Oliver 1655. The hitch linkage had been just bolted together the little U shape stop that keeps the lift links from floating where both gone. They where not the worst at $35 dollars each. I had them order the two short pins that hold those links in. They where $65 dollars each. WHAT??? I return them and use two Cat I top link pins cut off and re-drilled the holes. Those pins cost me less than $5.
I really think AGCO is trying to get guys to quit using the older lines they bought. The parts have gone crazy high the last few years.
Agco dealer,Maibach in Creston Ohio,agpartsfirst.com among others,depending on what you need.
I have to agree with you there. It was a nightmare trying to rebuild the hydraulic pump on my MH 444 after Agco had their way with the parts catalog.
I second Maibach. I've used them for a few years now, and their service has been outstanding. I feel that their prices are very reasonable, and they are very knowledgable about the older tractors and equipment.
Josh
