Dave H(NY)
New User
Well I think the pump went. Now I need help. I have zero diesel experiance. Here's the deal was running ok but under a constant acceleration it would slow down, I would throttle down then I could accelerate again and it would be fine. I had the tractor sitting and running and it shut down, would not restart, I hit it with ether and it started I parked it shut it down and wouldn't re-start. I tried again after a day and nothing just cranks. If I play with the throttle it sounds like it's going to start then just sputters and cranks again. I would like to try and rebuild the pump and replace that plastic part everyone talks about that breaks and doesn't allow the governor to work properly. Can you guys direct me where I should go to get everything.
