FORD 2000 FUEL PUMP PROBLEM?
Jim Walsh
New User
I have a ford 2000 that runs ok when its cold but as it warms up I have to pull the choke out to keep it running. When it gets up to operating temperature it stalls out even at full choke and wont start till it cools off again. Could it be the fuel pump? Do fuel pumps act like that or do they either work or dont work?
Best to ask your Ford questions on the Ford board.
It's also best to always mention the year and model of 2000 that you have. Either a pre 65 4 cyl or post 1965 3 cyl model. Assuming you have a 3 cyl model;
There are no less than 4 fuel filters on that tractor. First one in the fuel tap at the bottom of the tank. Second one is a screen in the top of the fuel pump on the front of the engine. Third one is a sediment bowl with a screen in it behind the carb. Last one is in the brass fitting where the fuel line goes in to the carb.
Make sure they are all clean before making any assumptions about the carb.
Thanks Ultradog! I didnt know there was a filter at the fuel pump. I will check that today! It is a three cylinder by the way!
