2176 cub cadet
Anonymous-0
PTO Just quite working after backing up with my tractor.
Where is the reverse switch located and can anyone tell me where to get a wiring diagram for the 2176 tractor.
Thank You
I know that -----Its just not working---when you begin to go forward you push in the pto switch and then pull it back out for the pto work but it does not
When youhave weight on the seat will the clutch even click ? How many hours are on it ? If you have power to the clutch .. could be air gap or a relay.
Sending Mail
I have a 2186, will look for wiring diagram which should be the same. Should be a fuse under hood in dash area that you might check first.
