How to remove the crank receiver on a 53 jubilee?
dp4kids
New User
I am putting a wagner WH3 loader on my 53 golden Jubilee. I need to take the handcrank receiver off of the front pulley so I can bolt the receiver for the shaft on the hydraulic pump. I need to take the hand crank pc off. Can someone tell me what to do?
Thanks!
Dick
Isn't it just a 1 1/8" bolt with the fingers for the crank on the end of it?
You should be able to put a deep socket wrench on it and unscrew it. If it is tight and the engine turns over while trying to loosen it use a breaker bar and slug the handle with a block of wood or something. Replace it with a bolt of suitable size.
EZ
Thanks for the photo, I assume it is a right hand thread. I will get a long 4X4 and give it a big hit.
DP
