We bought two used KRONE balers in April 2007.
Both were built in the late 1980s.
<a href="http://s200.photobucket.com/albums/aa5/jameslloydhowell/Krone%20Balers/?action=view�t=260-125.jpg" target="_blank">
</a>
The smaller KRONE 125 is the 4x4 baler we use in the Coastal Bermuda hay meadow.
<a href="http://s200.photobucket.com/albums/aa5/jameslloydhowell/Krone%20Balers/?action=view�t=125-2.jpg" target="_blank">
</a>
It is a fixed chamber baler with rollers.
<a href="http://s200.photobucket.com/albums/aa5/jameslloydhowell/Krone%20Balers/?action=view�t=125-3.jpg" target="_blank">
</a>
There is a slip clutch on the drive shaft.
It has a manual tying system and the string knives need to be kept sharp to prevent tying problems.
Most of the maintenance can be done with a 13mm wrench.
The small 4x4 bales are easier for Nancy to handle when feeding her horses.
<a href="http://s200.photobucket.com/albums/aa5/jameslloydhowell/Haymaking%202011/First%20Cutting%20Hay%20Field/?action=view�t=013.jpg" target="_blank">
</a>
The bales are are soft-core bales and usually form a "star" pattern like the one on the right.
<a href="http://s200.photobucket.com/albums/aa5/jameslloydhowell/Haymaking%202010/First%20Cutting%20Long%20Hill/?action=view�t=017.jpg" target="_blank">
</a>
It has a good pickup and <a href="http://youtu.be/XEaqc2pXPgI">leaves very little on the ground</a>.
There is only <a href="http://youtu.be/H_1_iWV9WqE">one hydraulic line</a> on this baler.
<a href="http://s200.photobucket.com/albums/aa5/jameslloydhowell/Krone%20Balers/?action=view¤t=125-4.jpg" target="_blank">
</a>
The 4x4 baler <a href="http://youtu.be/7X1TPAUgf38">requires a minimum 35hp tractor</a>.
Hope this helps.
