Bill in IL
I have a 12 volt Delco 2 brush generator setup on my old michigan loader. Couple of days ago it quit charging. I have used old John T's generator troubleshooting blurb and can't figure this one out.
Battery is good as it took a charge from a bench charger. Still starts the machine with no problems.
Generator works well when I try to motor check it. Spins it over with the belts loose but still dragging. When I ground the field terminal I get no output. When I ground the field and jumper the batt to arm I still get no output.
I am about ready to go buy an alternator but would like to know whats wrong before I go replacing things.
