hanks that helped(quoted from post at 22:05:14 02/14/12) i guess there is all kinds of questions here that i have done when 15yrs. old. dont matter if its hand crank or electic start. i hate writing storys , but just hook up to it and put the front tractor in a lower gear and the rear tractor in a higher gear and have the clutch depressed. then once rolling let out your clutch and it should start within 5'. then step on clutch and take it out of gear and have front tractor stop. maybe have someone with some tractor experience give you a demo.hate to see you run into the pulling tractor. i have pull started tractors by my self by jumping off the front one and starting the rear one then jumping off and stopping the front one.
(quoted from post at 03:33:54 02/15/12) Pull started by myself also for years. Since I have a problem walking fast now let alone run I doooon't think I'll try it again. I tried push starting by myself a while back and that didn't even work out like I figured. ^D
Skid tracks of the push tractor as both front tires of the front tractor each hit the rear tires of a parked tractor at the same time.
Sorry no video. ^D
<img src=" http://images16.fotki.com/v258/photos/6/34676/9322021/001-vi.jpg">
(quoted from post at 05:56:47 02/20/12) Pulling one vehicle with another is inherently dangerous when using a rope/chain/cable/tow strap. Always has been and always will be. Trying to pull start a vehicle makes it more so. Just because you have done it for years without any accidents or injury isn't an indication that it's safe. As people have mentioned it can be done without problems but people need to be aware of the dangers and need to communicate to accomplish it without problems. Even the US Army discouraged tow starting stuff as early as 1974 and also had tow bars rather than chains for pulling things any distance. Now take someone who joined in 74 to be a clerk or cook. Most of those people never were in a situation where they NEEDED to know any of those things. By 96 almost everthing was auto tranny and couldn't be towed started.
As others have stated, lower gear on the towing tractor. Higher gear on the tractor you are trying to start. You want the non running tractors engine to spin over pretty good. Before starting you need to be sure that you have good spark and fuel plus that the tractor being pulled has good brakes. The chain/rope/cable/strap needs to be in good condition.
If you look at it a lot of people today have no idea how to pull start another vehicle, or for that matter by rolling one down a hill. Isn't thier fault they grew up in a time where most new cars and traucks have auto trannies. They are not stupid because they have never had to do it. And that sure don't mean that they shouldn't own something. Lacking knowledge or experience IS NOT an indication that someone is stupid. They are only stupid when they can't learn generally through NO FAULT OF THIER OWN!
Rick
(quoted from post at 08:25:18 02/20/12) Given the number of incidents that occur with
wrecked equipment, property damaged and injured or
killed personal.
It's reasonable to presume there are some people
not as smart/safe/capable as you.
(quoted from post at 16:32:17 02/20/12)
