O/T more accurate measuring
Anonymous-0
On the old mill, the first pic is the chain system that was on it. I was having problems keeping it consistant. I built a more stable system that seems to work alot better :D
Lyle, mill down the road has two cleaning chains, one under the mill, and a second going out the side to a pole. The pole chain is elevated and eventually builds a pile outside that builds it's own elevator as it cleans. When a truck comes in for sawdust, they just drive a loader in to the pile created under it.
Could you take a better pic of the ratcheting system that's used to pull the headblock's forward? You should have stop pins that can be set in 1/4 in increments for any thickness board you want to pull consistently. A piece of belting or old tire with a rail notch cut out should be bolted to the rear of the carrage on one side and a straight piece on the other side to keep your rails clean.
(quoted from post at 04:37:49 02/10/12) Lyle, mill down the road has two cleaning chains, one under the mill, and a second going out the side to a pole. The pole chain is elevated and eventually builds a pile outside that builds it's own elevator as it cleans. When a truck comes in for sawdust, they just drive a loader in to the pile created under it.
here was a sawdust blower for the mill but I cant seem to get it to run properly, This week I will be adding a belt drive sawdust chain.
(quoted from post at 07:18:52 02/10/12) Could you take a better pic of the ratcheting system that's used to pull the headblock's forward? You should have stop pins that can be set in 1/4 in increments for any thickness board you want to pull consistently. A piece of belting or old tire with a rail notch cut out should be bolted to the rear of the carrage on one side and a straight piece on the other side to keep your rails clean.
will get a better pic for you of the system. I will be adding some sweeps for the rails soon..
