Anonymous-0
been watching your post bout the old 1 ton ford, no biggey to get a master cly to work on it for off road use. just go to the junk yard get a good one that is bout the same size, build a adapter plat to bolt to the ford fire wall, build a rod from brake pedal to master cly with bout a 1/8" free play, put a tee on the master cly so you have 1 line to tie into the ford line bled em and go. I have a 46 chevy army truck with a 1975 datsun master cly tie into 1 datsun disk brake on the tranfer case, stops on a dime and gives you change back. also have a 76 chevy 4x4 with a 4 cly isuz diesel the turbocharger is in the way for the vacumm can on the master cly on that one, had to use a hydraulic assist unit off a 86 one ton chevy, then trun it upside down to clear the turbcharger, benn stopin her for 5 years that way.
